Daylight Savings vs. SQL
By Greg Enns posted 03-12-2018 10:02 AM
I still remember the first day I realized that my SQL reports had datetimes in UTC. Oh...the horror! (Yes, I was newbie with lots to learn.)
It's taken me a few years to get it right, but I finally found a function that works year-round to convert my datetime values to the correct datetime.
The trick is to get it to work both during daylight savings AND outside of. There are lots of solutions on the web--many of which I tried and didn't work year-round. I was hopeful when I tried this one last November, and today I can finally confirm that it works. Hope this helps someone else out there! (many thanks to whomever posted this in a SQL forum somewhere/sometime--You get all the credit!)
/****** Object:  UserDefinedFunction [dbo].[UtcToLocalTime]    Script Date: 3/12/2018 8:38:43 AM ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE FUNCTION [dbo].[udfUtcToLocalTime]
    @UTC datetime
RETURNS datetime
AS
BEGIN
    declare
        @DST datetime,
        @SSM datetime, -- Second Sunday in March
        @FSN datetime,  -- First Sunday in November
             @StandardOffset int = -6  --Timezone adjustment (-6 = Central US)
    -- get DST Range
       set @SSM = datename(year,@UTC) + '0314' --start with max possible date
    set @SSM = dateadd(hour,-@StandardOffset,dateadd(day,datepart(dw,@SSM)*-1+1,@SSM))
    set @FSN = datename(year,@UTC) + '1107' --start with max possible date
    set @FSN = dateadd(Millisecond,-2,dateadd(hour,-@StandardOffset,dateadd(day,datepart(dw,@FSN)*-1+1,@FSN)))
    -- add an hour to @StandardOffset if @UTC is in DST range (summer)
    IF @UTC between @SSM and @FSN
        SET @StandardOffset = @StandardOffset + 1
    -- convert to DST
    IF @UTC = '17530101'
             SET @DST = @UTC
       ELSE
             set @DST = dateadd(hour,@StandardOffset,@UTC)
    -- return converted datetime
    return @DST
END
GO
1 view
