Traci
Unfortunately, you will have to have your VAR/Partner write a customization to change the dimension values on posted document(s). After NAV 2009 (6.0), the dimension set id was introduced and swapping a dimension value on the table level went away. Your VAR/Partner will have to write a customization to identify if the new dimension set id already exist. If it doesn't, it must request a new set id from NAV and apply it to the transaction (posted document, ledger entries & GL entries). Not a rare request at all.
Reach out to them, Good Luck!
Alfredo Zelaya
Sr. Systems Analyst
Megadyne Americas LLC
Fairfield NJ
Sent: Aug 12, 2019 10:41 AM
Subject: Changing Dimensions after posting
RE: NAV 2017
We use dimensions to track expenses and Assembly Orders created for a specific Job. Sometimes invoices are posted without the correct dimension. Sometimes Assembly Orders are created for stock and then pulled off the shelf and need to be assigned to a specific job dimension. Is there anyway to change the dimension code for an invoice, assembly order, or any other document once it is posted in NAV other than reversing and recreating with the correct dimension codes?
Thank you,
Traci Albosta
Comitt Well Solutions LLC
Katy TX
