If you set the Assembly items to Assemble to Stock vs Assemble to order, they will be put in inventory and then can be picked against the warehouse shipment.
Using Assemble to stock will require you create the Assembly order from planning or manually and "output" them but they will then show in stock.
You can also use the explode function that will explode the assembly order and create individual lines on the sales order for the components.
There are always trade offs, especially in Make to Order environments.
Kevin Fons
Windsor WI
Sent: Jan 25, 2021 11:45 AM
Subject: BC - Manufacturing or Assembly
We use both Manufacturing and Assembly, and both work fine to meet the need they addressed. One thing I will call out that has been an issue for us is an EDI shortcoming.
We have a number of customers that require an ASN for shipments. We also use a separate application for managing our warehouse (shipments, receipts, etc.). We use assembly items to essentially pick to order certain Kits (grab X units of finished good A, Y units of finished good B, and Z units of finished good C and it all ships as V units of finished good ABC). Unfortunately, our WMS never sees item ABC in stock, and the container data shows the components instead (A, B, and C). When this uploads to NAV, we post the assembly order to consume the components and create item ABC, which is then consumed itself as the sales order posts as shipped. We found this was an issue for ASNs because the customer doesn't know what the components are (we can't send an ASN container referencing A, B, or C), and also because there is no shipping container that actually contains ABC (it could have parts spread across multiple pallets). So, for those customers, we had to create a new item ABC2 that is produced by a production order. The routing instructs how to pack it so we can send the ASN (banded cartons, custom Pallets, etc). I'm sure others have resolved this problem, but we never have. Just something to consider if this might apply to you.
Jason Luchka
siffron
Twinsburg OH
Sent: Jan 25, 2021 09:52 AM
Manufacturing is typically the way to go in most cases. Here's a short YouTube clip from a Business Central podcast that talks about the differences between Assembly and Manufacturing that may help you: https://youtu.be/GwvlNwGjc8U
Michael Intravartolo
Marketing Manager
Solution Systems, Inc.
Rolling Meadows, IL
michael@solsyst.com
847-590-3000
www.solsyst.com
A Shot of Business Central and A Beer Podcast: www.solsyst.com/podcast
Sent: Jan 21, 2021 12:19 PM
I'm looking to recommend either manufacturing or assembly. The process is taking materials (designated more or less by BoMs) and putting them together for a mixed finished product. Everything is either liquid or granular using a combination of gallons, cubic yards, liters and cubic meters (depending on the BoM design specs). We have a plant in Canada and another in US which does add complexity but I'm getting off topic here.
Which product would be best suited for this application?
Stephen Hoffort
4036500530
Calgary AB
