Lanham EDi 860 map POC02=RZ
  • 1.  Lanham EDi 860 map POC02=RZ
    Posted 5 days ago
    Hello Everyone,
    I'm looking for assitance with a Lanham EDI860 map.
    In the POC-02 I have mapped DI and AI (Delete Item and Add Item Values) and it works,
    I have a new situation where RZ (Replace All Values) is being received in the POC-02 and the POC-04 is NOT being used/mapped.  How do I map it so RZ will trigger a replace all values?
    October 6-9, 2020
    Nashville, TN
  • 2.  RE: Lanham EDi 860 map POC02=RZ
    Posted 4 days ago
    Hi Lewis,
    In order to account for the "RZ" EDI Code - Replace All Values - you will need to map a Conditional to send the value to the sales line "EDI Code" field for the POC 02. Then map conditionals on the POC 04, POC 05, and POC 11 using the same setup (Cond. Segment = POC, Cond. Element = 02, Cond. Value = RZ). See the attached screenshots for example mapping. I tested this set up in version SE0.61 but if it's not working for you, please send the Lanham EDI version (Go to E.D.I. Setup page >> About EDI….it's the SE0.xx.xx #) you're on and I will help troubleshoot further.
    Thank you,
    Margaret
    Margaret Mextorf
    EDI Support Specialist
  • 3.  RE: Lanham EDi 860 map POC02=RZ
    Posted 3 days ago
    Thanks for the reply @Margaret Mextorf.
    I'm on version 60.03 and it doesn't seem to be working.
    The only difference I saw was that I had "AI" and "DI" along with "RZ" set up in the conditionals for POC-02, but I tried it both ways.
    They are also sending the Qty in on POC-03 and not using POC-04, but I used the conditionals you had on PC-04 on element 03 instead.
    October 6-9, 2020
    Nashville, TN
