RDLC, sum iif "Global dim code = 1..9
  • 1.  RDLC, sum iif "Global dim code = 1..9
    Posted Jan 03, 2019 04:12 AM
    Hi.
    Standard NAV report ID: 1011 Job Suggested Billing
    How do I get Totals, by "global dimension code", where code is from 1..9
    Blue is code 9, and totals goes to BLUE Circle
    Red is code 3, and totals goes to RED Circle
    I have tried this: (but I gives me an error, on report run)
    =Sum(IIf(Fields!AfdelingsKode.Value = 9, Fields!Amt6.Value,0))
    Henrik Jensen
    IT Chief
    Ocean Prawns A/S
  • 2.  RE: RDLC, sum iif "Global dim code = 1..9
    Posted Jan 04, 2019 09:33 AM
    Hard to know without seeing the error, but perhaps the 1..9 is actually a text character and not an integer? If so then you might try =Sum(IIf(Fields!AfdelingsKode.Value = "9", Fields!Amt6.Value,0))
    Kaukauna WI
