Dimension Decision Tree
  • 1.  Dimension Decision Tree
    Posted 15 days ago
    Is there a way in NAV base or with coding to make a Dimension have more of a decision tree feel?
    More or less: You select Dimension A first and then based on what you select there Dimension B only shows results tied to that?
    Example: You select Medical in Dimension A, and then in Dimension B only options related to the Medical (ER, Chiro, OBGYN, etc) would come up to be selected vs the entire list in Dimension Value?
    Andrea Riviezzo
    Functional Analyst
    Charlotte's Web, Inc.
    Louisville CO
  • 2.  RE: Dimension Decision Tree
    Posted 15 days ago
    @Andrea Riviezzo you may be able to use Dimension Combinations for this. Dimension Combinations can be defined to avoid posting entries with contradictory or irrelevant dimensions. You can block or limit specific combinations of two dimensions. A blocked dimension combination means that you cannot post both dimensions on the same entry regardless of what the dimension values are. A limited dimension combination lets you post both dimensions to the same entry, but only for certain combinations of dimension values.
    You can find Dimension Combinations by using Search or Tell me depending on your version.
    Cynthia Priebe MCP, DCP
  • 3.  RE: Dimension Decision Tree
    Posted 15 days ago
    Hi Andrea,
    I agree with the Cynthia ,you can use "Dimension Combination" feature to define the combination of dimension,say if Dimension B is defined as blank with the Dimension A, then combination is allowed to use.
    If you want to put validation on dimension value then there needs to be put custom code.
    DEEPAK KUMAR
    BC/NAV Consultant
    AlleTechnologies Inc.
  • 4.  RE: Dimension Decision Tree
    Posted 13 days ago
    You could also try building the hierarchy within the dimension values page itself.  Using this you can build the groups and then the actual selectable values underneath the group.  The user would just select one value but still gives you the option of reporting at the posting level or the group level.
    Project Manager
