General Posting Setup - Received Not Vouched
  • 1.  General Posting Setup - Received Not Vouched
    Posted Feb 27, 2019 02:49 PM
    Edited by Nathan Romney Feb 27, 2019 08:02 PM
    Hi.  I'm looking for some quick guidance on the General Posting Setup for a vouchers payable (received not vouched) process/account structure.
    As is typical in accounting, in the event we receive an item into inventory prior to receiving the Vendor Invoice, the inventory asset account is debited with the value of the items received and the balancing credit is posted to a Vouchers Payable (Received Not Vouched) liability account.  Later upon receiving the Vendor Invoice the invoice is entered (using the "get receipt lines" function) and the posting debits Vouchers Payable (Received Not Vouched) and credits Accounts Payable.
    I know this is a standard process, but I'm having a hard time figuring out where in the General Posting Setup matrix I'm supposed to put the Vouchers Payable account number for both the receiving action and the invoicing action.  The General Posting Setup column headers do not appear to be very intuitive.  Is there an outline somewhere that shows each accounting transaction's posting map of the General Posting Setup?
    Also, is there a setting that needs to be turned on to have the purchase receipt post to the G/L at the time of the receipt?  When I navigate to the entries on the Purchase Receipt is appears that it is just hitting the Value and Item Entry tables and not posting to the G/L.
    Any thoughts/guidance is greatly appreciated!
    Nate
    Nathan Romney
    CFO
    Martori Farms
    Scottsdale AZ
  • 2.  RE: General Posting Setup - Received Not Vouched
    Posted Feb 28, 2019 09:51 AM
    Nathan,
    The field you are looking for in the Gen Posting Setup is Invt. Accrual Acc. (Interim). It handles the Vouchers Payable portion of both the receipt and Purchase Invoice posting.
    Amanda Mayer
  • 3.  RE: General Posting Setup - Received Not Vouched
    Posted Feb 28, 2019 11:44 AM
    Nathan, Amanda is correct for the account number. You also asked about a setting to turn on the posting of the receipt accrual and that exists in the Inventory Setup, the field for Expected Cost Posting. When that boxed is checked, receipt accruals will be generated.
  • 4.  RE: General Posting Setup - Received Not Vouched
    Posted Feb 28, 2019 12:03 PM
    Ah, @Kim Dallefeld, I totally missed that question! I would add that if you are turning on Expected Cost and you already have transactions mid-stream (i.e. Received Not Invoiced), do the research to determine the lines that are affected so that you can verify all entries clear out correctly. This can be especially tricky if you previously had it turned on and turned it off.​
    Amanda Mayer
  • 5.  RE: General Posting Setup - Received Not Vouched
    Posted Feb 28, 2019 01:39 PM
    That's great!  Exactly what I was looking for.  Thanks so much!
    Nathan Romney
    CFO
    Martori Farms
    Scottsdale AZ
  • 6.  RE: General Posting Setup - Received Not Vouched
    Posted Mar 01, 2019 09:00 AM
    Nathan,
    Kim and Amada's advice is correct. But based on your original question, I believe you were looking for the following transaction flow
    Dr. Regular Inventory
    Cr. Uninvoiced AP
    then upon receipt of invoice
    Dr Uninvoiced AP
    CR Regular AP
    NAV posts differently ( due to the addon nature of Expected cost posting)
    Receipt
    Dr. Interim Inventory
    Cr Uninvoiced AP
    When Receipt is posted
    NAV first posts the reversal of the receipt
    Dr Uninvoiced Receipts
    Cr Interim Inventory
    then
    posts the invoice
    Dr Regular Inventory
    Cr  Purchase Invoiced Applied( a Clearing account that exists for some reason)
    Dr  Purchase Invoices Applied
    Cr Accounts Payable
    Dr/Cr PPV Variances ( if using standard cost)
    In dealing with Expected cost and the General Posting setup understanding this flow is very important.
    And heed Amanda's warning ,    it is a decent sized project to turn Expected Cost on midstream.
    Michael Carr
    VP , Finance
    Philadelphia Scientific LLC
    Montgomeryville PA
  • 7.  RE: General Posting Setup - Received Not Vouched
    Posted Mar 01, 2019 01:05 PM
    Thank you Michael for the clarification on the transaction accounting.  Is there a best practices as to which G/L account to use for the Purchase Invoice Applied clearing, and what is the name of the General Posting Setup column header that is for the Purchase Invoice Applied posting?
    Nathan Romney
    CFO
    Martori Farms
    Scottsdale AZ
  • 8.  RE: General Posting Setup - Received Not Vouched
    Posted Mar 01, 2019 05:00 PM
    I would suggest that you review the Bob Bergman (RIP) webinar located at https://msdynamicsworld.com/webcast/dynamics-nav/cost-accounting-manufacturing-microsoft-dynamics-nav-strategies-success for a fuller explanation.   The two columns in general Posting setup are Direct Cost Applied and Purchase invoice.
    Best Practices says to have each post to a separate consecutive accounts so you can easily spot any imbalances. I forget which is for which to be honest.
    Michael Carr
    VP , Finance
    Montgomeryville PA
