Navision 2017 (Add New User)
  • 1.  Navision 2017 (Add New User)
    Posted 26 days ago
    In Nav 2017, there are 2 new users created under Domain & they are found under Active Directory as well.
    Open NAV as NAV ADMIN, go to users.
    Select NEW.
    Enter the USER ID
    Enter User Name
    License Type: Full User
    The user is Enabled.
    Now the main part:
    when I click on Windows User Name, I go in and select the user name from the Entire Directory.
    Once I found the name, I select it and click OK.
    The moment the name is copied into the Windows User Name, it throws an error message as
    You Do Not Have Permission for this action.
    Later I receive a warning message where it says that i am trying to rename a user and it will rename the existing record.
    but i am not renaming the user, i am creating a new user by clicking on NEW Function in the user setup.
    Any clue as why I am coming across this kind of an error message.
    Note: I have logged with my user ID and my role is assigned as SUPER.
    Regards
    Khan
    Khan Wajahatullah
    Hydro Style Pte Ltd
    Singapore
  • 2.  RE: Navision 2017 (Add New User)
    Posted 26 days ago
    Have you tried filling out the Windows User Name first before the USER ID?  For us, when we fill out the windows user name first, the user id fills in automatically.  Then we just need to fill in the user name.
    Jonathan Delfraisse
    Computer Specialist
    MANCON
    Virginia Beach VA
    NAV 2015
  • 3.  RE: Navision 2017 (Add New User)
    Posted 26 days ago
    Hi Jonathan,
    Thank you for your reply.
    It was right on target, it worked the way you mentioned.
    Users/New
    Call Windows User Name, Click OK.
    The User ID was automatically copied, just filled up the name.
    Thanks a lot Jonathan.
    Regards
    Khan
    Khan Wajahatullah
    Hydro Style Pte Ltd
