BIN CONTENT CREATION WORKSHEET
  • 1.  BIN CONTENT CREATION WORKSHEET
    Posted 16 days ago
    Hi All,
    The "Location Field" always choose same Location code by default and it cannot be change with any other location code while running "BIN  CREATION WORKSHEET".  We have multiple locations and I am trying to run Bin Creation Worksheet to create Bin's for different locations.
    Appreciate your help on this issue.
    Ranjith E S
    Functional Consultant
    SFO
  • 2.  RE: BIN CONTENT CREATION WORKSHEET
    Posted 16 days ago
    Ranjith,
    Are you setup as a Warehouse Employee in the other Locations?  I'm not sure this is the cause, but is easy to miss.
  • 3.  RE: BIN CONTENT CREATION WORKSHEET
    Posted 15 days ago
    Thanks Ben Baxter,
    Yes, it caused due to the ware house employee setup.
    Exactly you said, it easy to missed out.
    I was missed to setup the ware house employee for other locations and also the default location was enabled for the other location in the same.
    Thank you very much!
    Ranjith E S
    Nest Information Technologies
  • 4.  RE: BIN CONTENT CREATION WORKSHEET
    Posted 15 days ago
    The Bin Creation worksheet is designed to create bins for only one location at a time.  Even if you are set up as a warehouse employee in multiple locations, a different worksheet name is created for each location.  If you need to set up the same bin codes/names in multiple locations, you can create the worksheet for one location and then (before clicking on Create Bins), copy the lines and paste them into the other location(s).
    Project Manager
