Hi David,
For the example for the "Line No." :
Tooltip = Line number on the quote
ToolTipML = ENU=Line number on the quote
Nothing shows when hovering the mouse of that field, as the other fields below will.
The same ENU= works for the 4 fields on the bottom that are in the Group>Group part.
GovernmentAcquisitions, Inc.
Sent: Feb 15, 2021 02:10 PM
Subject: Tooltip in NAV 2017 on Subform
You should be able to set the ToolTip for any of the fields, whether Repeater or not. Are there entries in the ToolTipML property which may be conflicting?
Sr. Solution Consultant
2019-2020 Board of Advisors
BCUG|NAVUG All-Star
Sent: Feb 11, 2021 05:42 PM
I compare another field on the same page that is a sub-page(Sales Quote Subform PD) of the Sales Quote PD that I was able to use a tooltip and it would show however the others in the top of the page do not. For example one of the top fields is "Line No." when selecting it and then clicking on the properties icon and then entering anything in for the tooltip part nothing is showing after saving and running NAV unlike other pages.
I noticed that one is a under a group that is a repeater and I didn't know if that has something to do about it not showing. The fields like "Line No." you can click on for Aesc and Desc but no tooltip shows, the summary fields do show under the group>group but not group>repeater.
So my question is it not possible to have tooltip show on repeating fields in the subform of a page?
Thanks in advance!
