GL Account Card Dimensions
  • 1.  GL Account Card Dimensions
    Posted 13 days ago
    Is it possible to add/edit dimensions within the GL Account card for mapping criteria? If so how?
    In the picture below i'd like to either rename totaling or add something under No. of Blank users.
    Joseph Lau
    Citizens Parking
    Atlanta GA
  • 2.  RE: GL Account Card Dimensions
    Posted 5 days ago
    Not sure what you mean by the first question.  From the account card, the user would normally go to the Default Dimensions page to set dimensions and value posting settings for dimensions to assign to the account.  With development, you could add a fasttab to display and update the default dimensions for an account from the account card.  Is that the issue?
    As far as the other things you mentioned:
    Yes, you can change the caption setting for the Totaling field on page 17 (G/L Account Card) to read anything you want.  You can also add additional fields under the "No. of Blank Lines" on the card.  Would you be adding a field that already exists on the G/L Account table?  If so, just open page 17 and add the field.  if the field doesn't already exist in the underlying table, you will need to add it to the underlying table or link to it through the page.
    Beck Consulting
