Technical Development question about adding fields to a table
  • 1.  Technical Development question about adding fields to a table
    Posted Feb 08, 2018 04:15 PM
    I was hoping someone could answer a development question for me. When adding a field to a table i can see the field when I run the table from the development environment, but cannot see it as an available column when running thru RTC. How do I get the field to show up as an available column under "Choose Columns" in RTC?
    We are on NAV2013r2.
    Suzanne Godau
    Nav Support Specialist
    Ragozzino Foods
    Meriden CT
  • 2.  RE: Technical Development question about adding fields to a table
    Posted Feb 08, 2018 04:21 PM
    Hello Suzanne,
    you will need to add that to the page to be able to add as a column. We are on 2009R2, I'm guessing it would be alike. If you would like, please let me know what is the field and page you want to add to and I can send you screenshots.
    Alicja Gaweda
    IT Support Administrator
    Furukawa Rock Drill USA
  • 3.  RE: Technical Development question about adding fields to a table
    Posted Feb 08, 2018 05:07 PM
    Ahhh! Thanks so much!  I know how to do that but I was thinking that since it was a table, it wouldn't have a page.
    Problem solved!  Thanks again!
    Suzanne Godau
    Ragozzino Foods
    Meriden CT
