Remove a Group from the ribbon in BC
  • 1.  Remove a Group from the ribbon in BC
    Posted 18 days ago
    We don't use any of the options in the Show attached Group on the home tab of our ribbons. Has anyone figured out how to remove options and or groups from the ribbon. I am having no trouble with options from other tabs. Those I can control fairly easily in an extension.
    Example of Show Attached in a Ribbon
    Gregory Alford
    Tri Star Metals LLC
    Carol Stream IL
  • 2.  RE: Remove a Group from the ribbon in BC
    Posted 17 days ago
    Hi Gregory,
    There is a "LinksAllowed" property on pages. When you set it to "No", it'll get rid of the Show Attached section of the Ribbon.
    Morgan Heller
    Agropur Ingredients
  • 3.  RE: Remove a Group from the ribbon in BC
    Posted 17 days ago
    How do I access the "Links Allowed" property in an extension?
    Gregory Alford
    Tri Star Metals LLC
    Carol Stream IL
  • 4.  RE: Remove a Group from the ribbon in BC
    Posted 17 days ago
    Hi Gregory,
    Here is the documentation on how to set the LinksAllowed property: https://docs.microsoft.com/en-us/dynamics365/business-central/dev-itpro/developer/properties/devenv-linksallowed-property
    I'm still on NAV 2017, but I believe you would just add it to the page properties in your page extension.
    Morgan Heller
    Agropur Ingredients
  • 5.  RE: Remove a Group from the ribbon in BC
    Posted 17 days ago
    Unfortunately, it is not available in extensions. However, I did suggest it to Microsoft today.
    Gregory Alford
    Tri Star Metals LLC
    Carol Stream IL
