Description update upon editing account number - PO lines
  • 1.  Description update upon editing account number - PO lines
    Posted 18 days ago
    Is there a setting to turn off the description updating to the account description if you edit which account it goes to?  We have operators that will type into the description on a PO line and then realize it's the wrong account number and get very frustrated when they have to retype the description because it triggers upon changing the account number.
    Samantha Mahlen
    DTYS Consulting, LLC
  • 2.  RE: Description update upon editing account number - PO lines
    Posted 18 days ago
    No there is not setting to change this behavior. You can create a customization/extension to change this behavior. I would suggest that you teach your operators to copy the description before they change the account number, then paste it back in. Alternately, you could look at using Items (with Type = Service or Non-Inventory) instead of using G/L Account numbers.
    Andrew Good
    Oakbrook Terrace IL
