Powershell: Get job queue log entries - ALL companies
  • 1.  Powershell: Get job queue log entries - ALL companies
    Posted Dec 21, 2018 04:00 AM
    Does anybody do this....
    I have 50 companies, and I need to get daily status of the "Update currency Exchange rates" has status "Succes" or not.
    Can this be done with powershell ?
    Henrik Jensen
    IT Chief
    Ocean Prawns A/S
  • 2.  RE: Powershell: Get job queue log entries - ALL companies
    Posted Dec 21, 2018 03:02 PM
    I doubt that it can be done via PowerShell but if you are using NAV 2017 or higher you can use task scheduler to achieve similar results.
    You can create a task via code in NAV/BC and then you can decide the output method in code. It can be an e-mail, a file or any other way you can think of.
    How to use task scheduler - https://docs.microsoft.com/en-us/dynamics-nav/task-scheduler
    Saurav Dhyani
    Duluth
  • 3.  RE: Powershell: Get job queue log entries - ALL companies
    Posted Dec 27, 2018 02:42 AM
    Thanks.
    I build a report, that get status from all companies, the last 7 days.
    /Henrik
    Henrik Jensen
    IT Chief
    Ocean Prawns A/S
  • 4.  RE: Powershell: Get job queue log entries - ALL companies
    Posted Dec 28, 2018 08:10 AM
    You could do this with powershell if you call sql from shell. Then feed the data to a simple html page to show green or red per company. I could see something like that being useful to manage 50 companies status for a number of different statuses.
    Mathew Ealy
    Nav Support Specialist
    Rentokil N. America
    Reading PA
