New BC Implementation - what works best?
  • 1.  New BC Implementation - what works best?
    Posted 21 days ago
    I want to setup a holding company and 2 very different companies in BC.  Although I am the only current user and am migrating from QBO, I would like to build 3 companies using a shared Chart of Accounts.  My intent is that as I grow and add accounting managers to the companies that they would only have access to their particular business unit.  How easy is it to consolidate reports across these 3 entities?
    How easy is it to upload master data (chart of accounts, customers and vendors) from a spreadsheet?
    I have a front-end application that provides AR and AP transactions to be integrated into one Business Unit.  Is this easy to do in BC?  Will I need to purchase an additional power app?
    I'm trying to decide if BC is the best way to go and if I should be using one company with extensions or 3 separate companies.
    Any advice is appreciated.
    Thank you
    Stephen Hoffort
    4036500530
    Calgary AB
  • 2.  RE: New BC Implementation - what works best?
    Posted 21 days ago
    When you said:
    > should [I] be using one company with extensions or separate companies?
    I think you meant to ask you should set up one company and with DIMENSIONS * to split up the 3 different company transactions and reporting.
    (extensions, in the BC world, are software add-ons)
    Dimensions can be added and used for this, but I suspect that, if you need separate P&L and other reporting for your 3 different companies, you may be best to set them up as separate companies.
    You can certainly do data imports. to learn about Setting Up a Company With RapidStart Services
    You might want to start here:
    https://docs.microsoft.com/en-us/dynamics365/business-central/admin-set-up-a-company-with-rapidstart
    Seeking out a partner that has done multi-company QB to BC conversions to work you through the process and ask the additional questions would also be recommended.
    There are established QB to BC migration tools available.
    -Bob*
    Bob Stahr
    BTC - Business Technology Consulting  | http://bit.ly/wwwbtc
    bob@stahr.us
  • 3.  RE: New BC Implementation - what works best?
    Posted 21 days ago
    Thanks ... yes I did mean Dimensions.  Obviously I'm new to the BC/NAV world but not ERP implementations.  I have 18 years GP experience plus 4 year PeopleSoft.  My intuition was to build 5 separate companies and you have confirmed that.
    Stephen Hoffort
    4036500530
    Calgary AB
