  • 1.  Change Log: 5 fields: Lot Size, ReOrder Point, ReOrder Qty
    Posted Oct 08, 2021 01:20 PM
    We are considering turning on "change log" for:
    1.  Lot Size
    2.  Reorder Point
    3.  Reorder Quantity
    Our goal is to make sure we've updated all of our items as of a certain date - then, be able to run a report every X months to make sure we update "any items not updated within the last Y months."
    We have several people working on this at the same time - it's hard for us to know "what items still need updating?" without keeping a separate Excel sheet.
    Any thoughts or suggestions how to do this better?
    Is the change log a good approach?  Is that reportable?
    -Kevin
    Kevin Brennan
    Director of IT at Mayco Colors
    Hilliard, OH
  • 2.  RE: Change Log: 5 fields: Lot Size, ReOrder Point, ReOrder Qty
    Posted Oct 09, 2021 07:51 PM
    Kevin,
    If I follow you, you want to run a report every few months to see if 3 fields have be modified by a certain date. Change Log will record modifications to the 3 fields by date/time. This is a good way to achieve this requirement. You can create a Jet Report to produce the information from the Change Log and Item Card.
  • 3.  RE: Change Log: 5 fields: Lot Size, ReOrder Point, ReOrder Qty
    Posted Oct 09, 2021 11:58 PM
    Hi Steve,
    Thanks for validating that the "path to the goal" is feasible, and a good solution.
    I will ask team to look into.
    Regards,
    -Kevin
    Kevin Brennan
    Hilliard, OH
