Check stock for Report 10412 Check/Stub/Stub
  • 1.  Check stock for Report 10412 Check/Stub/Stub
    Posted Aug 20, 2019 06:03 PM
    Has anyone found check stock that aligns to the layout of Report 10412 Check/Stub/Stub in BC without customizing either the check or the report?
    Lisa Ready
    Lisa Ready CMA
    Dallas, TX
  • 2.  RE: Check stock for Report 10412 Check/Stub/Stub
    Posted Aug 21, 2019 09:41 AM
    Edited by Drew Kipfer Aug 21, 2019 09:47 AM
    Hi Lisa,
    **Edit** Sorry, on reading your message closer I see you had already mentioned Report 10412.
    Drew Kipfer
    EMP Technical Group
  • 3.  RE: Check stock for Report 10412 Check/Stub/Stub
    Posted Aug 21, 2019 11:53 AM
    Hi Lisa,
    It is extremely rare to have this happen.  We have had to adjust something for every client on the Check/Stub/Stub.  The only way to lessen this that I've seen is to have Blank Check Stock (no formatting at all).  Please be aware that BC does not accommodate Blank Check Stock as the MICR font is not a part of BC.
    Jenifer Elliott
    El Segundo, CA 90245
    Phone: 831.277.3280
    Email: jelliott@tmc-la.com
    Website: www.abouttmc.com
  • 4.  RE: Check stock for Report 10412 Check/Stub/Stub
    Posted Aug 22, 2019 12:36 PM
    Lisa, Check/Stub/Stub had always been the hardest to align. Apparently this was not fixed in BC.
  • 5.  RE: Check stock for Report 10412 Check/Stub/Stub
    Posted Aug 22, 2019 12:43 PM
    That is true Report 10401 Check (Stub/Stub/Check) and 10411 Check (Stub/Check/Stub) works fine including when applying entries more than 10 on a single Payment Journal line, however report 10412 Check (Check/Stub/Stub) does not. Very weir but I look for any cumulative update on preview version as 2018 and no fix.
    We need to be fix by Microsoft developers since is a lot of wait of time every time we come across this request
    Thank you
    Carlos G
    Carlos Garcia
    Software Developer-IT
    Ferd. Schmetz Needle Corp.
    Miami FL
