GL Detail Reporting with Dimension Detail
  • 1.  GL Detail Reporting with Dimension Detail
    Posted Jul 03, 2019 12:37 PM
    Is there a way to run/export to excel GL detail reports with dimension details all on one line from within NAV.  Currently the dimension details are only visible if you highlight a line and click on Dimensions in the ribbon.  For reporting and reconciling I need this information both visible on my screen with the other details and in an export.
    Suzanne Goeden
    Shepard AV
    Atlanta GA
  • 2.  RE: GL Detail Reporting with Dimension Detail
    Posted Jul 03, 2019 01:09 PM
    Are these Global Dimensions 1 & 2? If Yes, these can be added as columns to the page and exported to Excel.
    Alfredo Zelaya
    Megadyne Americas LLC
    Fairfield NJ
  • 3.  RE: GL Detail Reporting with Dimension Detail
    Posted Jul 03, 2019 03:06 PM
    Actually , you can add any dimensions, whether Global or Not, to the General Ledger Entries List (Source Table G/L Entry (17)---- Page: General Ledger entries (20) to export to Excel for analysis.  Again they do not need to be on just Global Dimensions. At least from NAV2013R2 to 2018.
    Michael Carr
    VP , Finance
    Philadelphia Scientific LLC
    Montgomeryville PA
  • 4.  RE: GL Detail Reporting with Dimension Detail
    Posted Jul 03, 2019 05:00 PM
    No, they are additional dimensions.
  • 5.  RE: GL Detail Reporting with Dimension Detail
    Posted Jul 05, 2019 08:31 AM
    As Michael mentioned above, you can go to the Development Client and add the "Shortcut Dimensions" to the page. You can export them to Excel. You don't need the developers license to do that, just access to the Development Client.
    Good Luck!
    Alfredo Zelaya
    Fairfield NJ
  • 6.  RE: GL Detail Reporting with Dimension Detail
    Posted Jul 04, 2019 12:41 AM
    Hi Suzanne
    Which version of NAV are you using?  I believe the Dimension Set/Dimension Set Entry were introduced from NAV 2013.
    If you do use Jet Report, it is simply a matter expanding the the Dimension Set ID (from Dimension Set Entry table) from the General Ledger Entries listing to reveal the additional dimensions.  As other users pointed out, Global Dimensions are already embedded on General Ledger Entries table.
    If you don't use Jet Report, then would create a customized report within NAV can achieve the same/ or other reporting methods.
    Leo Chen
    Systems Analyst
    Summit Fertilizers
  • 7.  RE: GL Detail Reporting with Dimension Detail
    Posted Jul 04, 2019 01:47 AM
    If you have Jet Reports it can do this for you. You might also be able to do this with the free version, Jet Basics.
    Janice Taylor
    Managing Director
    Reports Your Way Ltd.
    Toronto Canada
