Physical Inventory Counting Sheets
  • 1.  Physical Inventory Counting Sheets
    Posted Feb 11, 2020 02:26 PM
    On NAV 2017 when we calculate a physical inventory there is an option to sort by the Bin code first (under the Warehouse Entry).  When we choose the Bin Code, when the Journal will sort the list by Bin Code, but when we print the "Phys. Inventory List" it sorts by the Item #.  There is no option to sort by Bin Code only "Journal Template Name, ​Name.
    Is there something missing here?  Is this out of the box NAV, or a customization?  I've not run across this before. The list would print according to what option(s) were set from the journal.  It's not efficient.   We have to send the list to excel and then the list is so much different from the physical inventory journal, they don't want to use it.  We end up with an overrun of positive and negative entries from Item Journals.
    Any help would be appreciated.
    Xan
    Katy TX
