Powershell command Sync-NavTenant list is truncated
  • 1.  Powershell command Sync-NavTenant list is truncated
    Posted Apr 10, 2019 08:20 AM
    In upgrading to NAV 2018 one of the steps is to "Sync Schema for All Tables" which can be done from Dev environment or Powershell.  Powershell is better since you can see the output.  So when running this command: Sync-NavTenant [YourServiceTierName] -Mode Sync if there are destructive changes it rolls back and lists all of the tables and fields that are being changed or deleted like this for example:
    Table: 111, Sales Shipment Line
    Field: 84012, Return Item No.: Deleted
    Table: 113, Sales Invoice Line
    Table: 355, Ledger Entry Dimension
    Field: 1, Table ID: Data type changed
    Field: 2, Entry No.: Data type changed
    Field: 3, Dimension Code: Data type changed
    Field: 4, Dimension Value Code: Data type changed
    etc...
    This is totally expected during an upgrade and is typically resolved by using an upgrade codeunit.  Turns out that due to our add-on's there are so many changes to list that it truncates the list and I can't see all the changes.  Just as an aside, not a single one of our add-on's included an upgrade codeunit with their product to resolve this (not cool).
    So my question is this:  Isn't there a way to run a powershell command to a file instead of the screen which would most likely end up creating the full list?  Or some other way to see the full results from the Sync-NavTenant command.
  • 2.  RE: Powershell command Sync-NavTenant list is truncated
    Posted Apr 11, 2019 07:44 AM
    Add the out-file command to your script.
    Sync-NavTenant [YourServiceTierName] -Mode Sync -verbose | Out-File -FilePath C:\Sync.txt
    Mathew Ealy
    Nav Support Specialist
    Rentokil N. America
    Reading PA
  • 3.  RE: Powershell command Sync-NavTenant list is truncated
    Posted Apr 12, 2019 07:23 AM
    Exactly what I was looking for, thanks!
  • 4.  RE: Powershell command Sync-NavTenant list is truncated
    Posted Apr 12, 2019 08:13 AM
    I spoke too soon.  This:
    Sync-NavTenant DynamicsNAV110-2 -Mode CheckOnly -verbose Out-File -FilePath "C:\bin\Sync.txt"
    causes this error:
    A positional parameter cannot be found that accepts argument 'Out-File'.
  • 5.  RE: Powershell command Sync-NavTenant list is truncated
    Posted Apr 12, 2019 08:22 AM
    Edited by Mathew Ealy Apr 12, 2019 08:23 AM
    you need to include the pipe | , you are sending the output of the first command  to the out-file powershell command.
    Mathew Ealy
    Rentokil N. America
    Reading PA
