Troy,
OK, this answers my question. The negative entries DID NOT post to the Warehouse Entries as the Bin Code was blank. Your goal is to take the Location 01, Bin Code = Packaging, and eliminate the 202,400, correct? If yes, here is my suggestion...
1. Using an Item Journal, first reverse the 2 Negative Entries which DO NOT have a Bin Code (create a Positive Adjustment). Please make sure you use the correct Posting Date as the next entry is the correction one.
2. Now that the 2 negative entries are eliminated from the Item, using the same Posting Date so this all washes to 0, lets create a correct Negative Adjustment entry, which points to Location 01 and Bin Code = Packaging. Post this entry and you will see the Bin have a Qty = 0.
This should solve the issue you are trying to acheive.
Sent: Jan 04, 2021 02:56 PM
Subject: Quantity in Bin Contents NOT in on-hand
Steve,
When I navigate on the Posted Purchase Receipt I find a couple of things.
1. I find that there are 2 ILE postings for each "Receipt" BUT only 1 Warehouse Entry
PR114208
ILE Warehouse Entry
a. -101,200 NO ENTRY ON TABLE
b. 101,200 Posted to Packaging (Bin)
PR114212
After seeing this I did find out that the Warehouse Manager added the -101,200 on he receipt to try to "fix it" TWICE. Now I am thinking that these are not applied entries however I took a quick look (I spent a whole 2 minutes looking around) and didn't really see what to apply.
Troy Harkness
Miller Baking Company
Milwaukee, WI
Sent: Jan 04, 2021 01:57 PM
Troy,
Using the images below, I see in the ILE 3 Purchase Receipts and 2 with an offsetting Negative Qty. On the Warehouse Entries, which are for the Bin entries, I see 3 Receipts, 1 Transfer from Location 01 to Location 03 and 1 Pos/Neg that washes to itself. My question now is where did the 2 Negative PO Lines from the Receipts get posted too in Location 01. My gut is telling me they are NOT in a Bin or Bin = '' (this means Blank). Can you Navigate on the 2 Posted PR document and see what Bin each record shows?
Sent: Jan 04, 2021 12:26 PM
Happy New Year Steve,
I have screenshots of Warehouse Entries and ILE to hopefully clear up the questions. The original receipt date was 10/18 however there are entries on both ILE and Warehouse Entries that involve the issue.
Troy Harkness
Milwaukee, WI
Sent: Jan 04, 2021 11:28 AM
Troy,
Happy New Year. I think I'm following your steps but a few questions... The Location you are posting too is Bin Mandatory and uses Advanced WMS? Also, you state that the negative PO Lines were posted on the same Posted Purchase Receipt, correct? The reason I ask is that the negative quantity, with Bin Mandatory, will not find a Bin with such a quantity until its received. I am just guessing this was a 2-step process?
Next question - I see the pic with the Bin Contents of the received 202,400, from the Posted Purchase Receipts. Can you look at the Posted Purchase Receipts and Navigate to the Item Ledger Entries and look at Location and Bin to see where the entry was posted too. Again, just asking questions to trace the steps.
Sent: Dec 31, 2020 11:25 AM
I have a bit of a mess with this one. We have a Purchase Order with two lines on it. Item 60420 with Qty 101,200 and a line for item 60420 with a quantity of -101,200. Posted Purchase Receipt has both on it, however only the 101,200 line has been applied to anything. We have another Posted Purchase Receipt for the same PO same Item and same two lines which also had been Received. Third Purchase Receipt with the correct Qty of 101,200 received, put-away and Invoiced. The On-Hand Inventory in NAV is correct however with these two received lines of 100,200 each totaling 202,400 is now what is showing in the Bin Content/Warehouse Entries. I do not want or cannot post an inventory adjustment as the inventory matches the physical inventory. This anomaly 200,400 qty is just sitting there. I have tried to do a Purchase Return which FAILED as there is no Inventory to "return". I tried to delete Bin Content that also FAILED. Any suggestions would be great.
We are using NAV 2017 On-Prem
Thank you,
Troy Harkness
Milwaukee, WI
