Barcode System Recommendations
  • 1.  Barcode System Recommendations
    Posted Nov 19, 2019 05:23 PM
    Our company uses NAV 2016 and is thinking about integrating a barcode system for shipping/receiving/inventory purposes.  Any recommendations along with pros/cons and issues regarding the product would be useful.
    Sara Sharkey
    Accountant
    Compax
    Salt Lake City UT
  • 2.  RE: Barcode System Recommendations
    Posted Nov 20, 2019 07:37 AM
    https://www.dmsiworks.com/products/mobile-warehouse-data-collection/  @Mark Hamblin is a top notch NAV / BC expert and built a product that really works.  The product adds the desired functionality and it isn't a giant and complex product where you will only use a small portion of it while paying for all of it  As your company grows you may be interested in the other products by InsightWorks.  Definitely worth adding this to your evaluation.
    Jason Nicolaou
    Engagement Manager
    Sikich, LLP
  • 3.  RE: Barcode System Recommendations
    Posted Nov 20, 2019 08:36 AM
    Good Morning Sara,
    NAV 2016 does have a light WMS system already in its ACDS and other WMS functionality. There is, however, limited functionality to NAV's WMS  and when companies are looking for much more robust Warehouse Management and Shipping capabilities, I can suggest both Insights Works and HighJump Warehouse Edge, which have tight integration to NAV.  We offer both of these WMS solutions for NAV and I welcome any questions.
    Sincerely,
    Greg Miles
    Marketing Manager
    iCepts Technology Group, Inc.
    Middletown, PA 17057
    gmiles@icepts.com
  • 4.  RE: Barcode System Recommendations
    Posted Nov 20, 2019 09:56 AM
    Boy, I wish we had used Insight Works. I have heard nothing but good about them. Instead we chose to use a solution offered by our partner. It was supposed to be a 3 month project, but it took 18 months. It was supposed to cost $30,000 and it cost us $120,000 and it still is not where we want it. Trust me, stick with the tried and true. I wish we had!​
    Gregory Alford
    Tri Star Metals LLC
    Carol Stream IL
  • 5.  RE: Barcode System Recommendations
    Posted Nov 21, 2019 07:07 AM
    Building on this reply. Make sure that you understand the discipline required by a WMS system. Mary Lanham makes a good point in another post. Start simple and get your feet on the ground before you get complicated.
    NAV/BC has a defined methodology for WMS that may or may not work well for you. Outline your needs and wants before you talk to a vendor. Then question them in depth to understand the rub points where your wants are different than their methodology.
    I have seen more than one WMS project fail because of no discipline in the warehouse or unexpressed needs or wants.
  • 6.  RE: Barcode System Recommendations
    Posted Nov 20, 2019 10:53 AM
    We use Lanham's ACE warehousing here at Gold Star Foods. We were able to modify it for our needs and it is working very well. We are on an older version, but I did see a demo of their latest version and was highly impressed with how they have enhanced the product. We also use Loftware to print our barcode labels.​
    Joseph Flynn
    Sr. Dynamics NAV Developer
    Gold Star Foods INC
    Ontario CA
  • 7.  RE: Barcode System Recommendations
    Posted Nov 20, 2019 02:49 PM
    Thanks for the strong reference, Joe!
    Sara, barcoding can be a very broad term. Barcoding is definitely used in Warehouse Management Systems, but you do not have to commit to that level of structure and control to use barcoding. If you are looking to barcode products as they arrive, so they can later be easily scanned for shipping, check out Lanham's E-Receive product here: https://www.lanhamassoc.com/e-receive.htm. This is a simple and inexpensive way to get started with barcoding. If you need more comprehensive WMS functionality, our ACE Warehousing solution can provide that as well.
    You should not have trouble implementing a system associated to NAV/BC to meet your needs. All Lanham solutions are built right inside NAV/BC so that you don't have to have cumbersome interfaces or worry about external data. Everything is in your NAV/BC User Interface for your database.
    Always feel free to reach out if we can provide additional information. 678-379-4200. Good luck with your endeavors!
    Mary Lanham
    COO
    lawrenceville GA
  • 8.  RE: Barcode System Recommendations
    Posted Nov 20, 2019 11:12 AM
    Good morning Sara,
    Another add-on that I am impressed with is Tasklet Factory. They have many of the standard type functions plus the ability to create custom ones as well. I think it is worth a look!
    https://www.taskletfactory.com
    Dale Raffauf
    In-Sys Solutions
    Libertyville, IL
    847-996-0400
    draffauf@in-sys.com
