Which server setting control web client timeout
  • 1.  Which server setting control web client timeout
    Posted 12 days ago
    Hi All
    We're testing BC2020, so no more RTC :-(
    There seems to be about a 10 minute timeout on the web clients. In MS docs it says SessionTimeout, but I don't see that anywhere in settings in admin shell
    Message
  • 2.  RE: Which server setting control web client timeout
    Posted 11 days ago
    There are two sets of timeouts in play. First is the web server IIS timeout, and second is the connection between IIS and the service tier. We are on BC16, and this is what we've settled on for settings, which have greatly reduced, but not eliminated, the "we've paused" message for users. The target timeout was 20 minutes.
    Note: if you deploy an app in the middle of the day, users will get that same error message.
    These are powershell commands.
    Service Tier:
    $instance = "whatever your instance name is"
    Set-NAVServerConfiguration $instance -KeyName ClientServicesKeepAliveInterval -KeyValue "00:00:15"
    Set-NAVServerConfiguration $instance -KeyName ClientServicesIdleClientTimeout -KeyValue "00:20:00"
    Set-NAVServerConfiguration $instance -KeyName ClientServicesReconnectPeriod -KeyValue "00:05:00"
    Set-NAVServerConfiguration $instance -KeyName NavHttpClientMaxTimeout -KeyValue "00:20:00"
    Set-NAVServerConfiguration $instance -KeyName SqlConnectionIdleTimeout -KeyValue "00:20:00"
    IIS:
    Set-NAVWebServerInstanceConfiguration -WebServerInstance $instance -KeyName SessionTimeout -KeyValue "00:20:00"
    Kyle Hardin
    Business Central Developer
    Atlanta GA
  • 3.  RE: Which server setting control web client timeout
    Posted 10 days ago
    Thanks Kyle, so it looks like you're just increasing it to 20 mins, no?
  • 4.  RE: Which server setting control web client timeout
    Posted 10 days ago
    Correct. You can change those to suit your needs.
    Kyle Hardin
    Atlanta GA
  • 5.  RE: Which server setting control web client timeout
    Posted 10 days ago
    Thanks Kyle
    That seems to have done the trick
    Mark Anderson | Director of ERP Systems
    Mobile 312.576.4332 | Direct 847.448.4202
