Delete Table that is "LinkedObject"
  • 1.  Delete Table that is "LinkedObject"
    Posted Dec 23, 2020 01:01 PM
    I'm trying to clean up old tables that we don't use anymore and re-use them. (BC14 On-Prem)
    We have a couple tables that are based on SQL views, so they are a "LinkedObject".
    I can delete them and the database synchronization works great. But when I try to create a new object in its' place, the database synch still seems to think the old table existed and is now being deleted--but even a "Force" doesn't work.
    I found this Mibuso post that is essentially the same issue. The solution there was to use some kind of "Database Check Tool" to sync a Metadata Snapshot. I have searched and cannot figure out what that means--or if that tool still exists.
    Has anyone found a way around this issue or any suggestions as to what the tool above is all about?
    Appleton WI
  • 2.  RE: Delete Table that is "LinkedObject"
    Posted 12 days ago
    Anyone have ideas on how to delete and re-use a table that was linked to a SQL view?
    Appleton WI
