NAV2017 - Using "Links" for General Ledger Entries
  • 1.  NAV2017 - Using "Links" for General Ledger Entries
    Posted 27 days ago
    Hello All,
    We are interested in using "Links" for the accounting group to add backup documentation when they post General Journals.  I can see how they would do it prior to posting the journal, but is there a way to add it after they post from the GL Entries or G/L Registers?  "New" doesn't appear to be an option.
    We are on NAV 2017.
    Thank you!
    Andrea Wasley
    Project Manager
    NOCO Energy Corp.
    Tonawanda NY
  • 2.  RE: NAV2017 - Using "Links" for General Ledger Entries
    Posted 26 days ago
    We use Incoming Documents to attach a pdf to the G/L entries both in the Journal entry before posting and after posting from the G/L Entries if needed.  You can also update the incoming document if you've attached the wrong pdf.
    Diane Gill
    Food Marketing Institute
    Arlington VA
