Cross Dock Bin Qty not balance with Item ledger entries
  • 1.  Cross Dock Bin Qty not balance with Item ledger entries
    Posted Apr 03, 2019 11:54 AM
    ​​We have a location that uses cross dock and it is not a setup as Direct Put Away in the warehouse setup.
    Item No. 1001
    The Cross Dock Bin is showing 1 pc while the item ledger entries for the item is showing 2 pcs.
    How do we fix the imbalance between the Cross Dock Bin and the Item Ledger Entries ?
    Physically, we got 2 pcs in the warehouse.
    I cannot do a warehouse item journal since this location is not setup as a Direct Put Away.
    What is the best way to increase the Bin Content but would not affect the Item Ledger?
    Berlinda Yap
    IT Service Manager
    Foremost Groups, Inc.
    East Hanover NJ
  • 2.  RE: Cross Dock Bin Qty not balance with Item ledger entries
    Posted Apr 03, 2019 12:09 PM
    ​My first thought would be to run Calculate Whse. Adjustments in the Item Journal, but since the location is not Directed put-away and pick, I suppose that will not help.  However, there's nothing to lose in trying this.
    I guess bin contents does not show the missing unit anywhere else?
    You can try drilling down on the 1 pc in Bin Contents to get to Warehouse Entries and then play with filters to see if there is 1 pc hiding anywhere.
  • 3.  RE: Cross Dock Bin Qty not balance with Item ledger entries
    Posted Apr 03, 2019 02:08 PM
    ​Dear Lewis,
    Will try what you suggested and update on this issue.
    Berlinda Yap
    IT Service Manager
    East Hanover NJ
