Template specifying No. Series
  • 1.  Template specifying No. Series
    Posted Sep 20, 2019 10:35 AM
    I need to know if there is a trick or a way I can set up a template that can be associated with a No. Series? I'm trying to setup an item card template that will select a non-default No. Series based on the type of Item. Any ideas?
    Chamus Gilbert
    Programer/Analyst
    OMT Veyhl
    Holland MI
  • 2.  RE: Template specifying No. Series
    Posted Sep 23, 2019 08:12 AM
    What version of NAV are you using?  The latest release has the No. Series as part of the Template:
    Item Template
  • 3.  RE: Template specifying No. Series
    Posted Sep 23, 2019 08:44 AM
    Edited by Chamus Gilbert Sep 23, 2019 08:44 AM
    2015, Good to know! This is exactly what I was looking for. We'll be there soon enough.
    Chamus Gilbert
    OMT Veyhl
    Holland MI
  • 4.  RE: Template specifying No. Series
    Posted Sep 23, 2019 08:25 AM
    Chamus
    You can't setup a number series on a template. You can use the ellipses to the right pick a number series for different types of items.
    Look at this Word document I created for another NAVUG call I created and see if it gives you insight.
    Alfredo Zelaya
    Sr. Systems Analyst
    Megadyne Americas LLC
    Fairfield NJ
    Attachment(s)
    docx
    Number Series.docx   195K 1 version
