Job Queue Entries - Starting Time changes every time it runs
  • 1.  Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 08, 2019 11:20 PM
    Hi everyone. I wonder if any of you have had problems when working with Job Queue Entries.
    This is the scenario:
    Version: NAV 20313 R2
    Vertical: LINKFresh
    I schedule Adjust Cost to run on the Job Queue Entries as follow:
    Job Queue Entries setup
    As you can see it is supposed to run at 9:00 PM tomorrow and it will actually run on time. The problem is after it runs it add 17 hours to the Earliest Start Date/Time even an I have it setup as No. of Minutes between Runs: 1440.
    Any ideas? I already checked my time zone and it is correct. I also checked the NAS instance
    Juan F Martinez
    Wholesum Family Farms Inc.
    Nogales AZ
  • 2.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 09, 2019 09:33 AM
    My observed behavior is that it queues based not on the time started, but the time ended.   [+1440]    If it is fast, it gets a little later each time.   If it is a lengthy process, it quickly moves to the middle of the day.    It does not behave in the traditional 'mainframe' model.    [set it for 10 PM, and it always starts at 10 PM]
    I had to customize to get it to work the way I wanted.    [Also added ability to run BOM/EOM/Same Day/Time Next Month - at least 2 of which are really something that should be core.
    Your VAR can do this if you don't have a dev license/developer.
    [I strongly advise that any changes of this nature be tested, re-tested, and re-tested again before deployment...took me a few kicks at the cat to get it working reliably in every scenario without compromising others]
    Joel
    Joel Baines, PMP, MCP
    Navision and EDI Business Analyst
    Oakville ON
  • 3.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 09, 2019 10:00 AM
    Joel is correct. The Job Queue has never quite worked like people expected. In this case, the job ends, it sees that it should wait 24 hours until the next time it runs, and adds that amount of time to the time it ended.
    Matt Traxinger
    San Antonio TX
  • 4.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 09, 2019 02:18 PM
    Matt:
    What you are telling me makes sense. Thank you
    Juan F Martinez
    Nogales AZ
  • 5.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 09, 2019 02:17 PM
    Let me give it a try Joel
    Juan F Martinez
    Nogales AZ
  • 6.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 09, 2019 09:40 AM
    For our daily job queue jobs, we have ours set to "Maximum No. Of Attempts to Run:" = 1, and "No. of Minutes between Runs:" = 0.  The recurrence check boxes will fire it on a daily basis so I don't believe you need to specify the minutes between runs.
    Mike Ashley
    Arbor Day Foundation
    Lincoln, NE US
    Mike Ashley
    Lincoln NE
  • 7.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 09, 2019 10:59 AM
    For jobs that I want to run everyday at a single specific time, I enter the desired "Starting Time" and leave the "No. of Minutes" at 0. During Daylight Savings half of the year, I have to adjust my times by 1 hour in order to get them to run when I want them to, but otherwise this works smoothly. (NAV 2016)
    Kaukauna WI
  • 8.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 09, 2019 02:32 PM
    I just looked this up. Looks like this was a known issue fixed in Feb 2019 CU for NAV 2013.
    https://support.microsoft.com/en-us/help/3024895/cumulative-update-22-for-microsoft-dynamics-nav-2013-build-39369
    "A job queue running on NAS calculates the Earliest Start Date/Time field for a job queue entry incorrectly."
    COD 448 TAB 472
    Looks like you might be able to fix your issue by updating those objects.
    Kaukauna WI
  • 9.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 09, 2019 02:51 PM
    @Greg Enns   Nice catch.    Hopefully he can use that solution.
    Oakville ON
  • 10.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 09, 2019 03:07 PM
    Thank you, guys. I already sent it to my partner that might speed the process instead of them telling me I am doing something wrong. Like usual
    Juan F Martinez
    Nogales AZ
  • 11.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 10, 2019 08:59 AM
    Greg's answer matches our experience. I was unable to get adjust costs to run in Job Queue  in NAV2013R2 CU16 .....gave up trying in the face of an imminent upgrade.  After updating to NAV 2018 the issue went away.
    Michael Carr
    VP , Finance
    Philadelphia Scientific LLC
    Montgomeryville PA
  • 12.  RE: Job Queue Entries - Starting Time changes every time it runs
    Posted Apr 10, 2019 10:07 AM
    Good to know. I am in the process of upgrading to NAV 2018 as well
    Juan F Martinez
    Nogales AZ
