RapidStart Export Packages
  • 1.  RapidStart Export Packages
    Posted Feb 18, 2020 11:58 AM
    I am working on am upgrade project with multiple companies. I would like to create all the RapidStarts in a Master Company and then export the packages so I can import into the other companies. When I complete the package export does this only export the headers or also the data? I am looking for a way to only get the headers as the companies will have different data in these tables.
    We are currently in #NAV2015 going to #D365BusinessCentral
    Thank you
    Rachel​​
    Rachel Boston
    Farmers Pride Inc
    Fredericksburg PA
  • 2.  RE: RapidStart Export Packages
    Posted Feb 18, 2020 01:46 PM
    Rachel,
    When you import a package, it imports all the package definitions and all data not filtered out by the definitions. This data is not automatically applied. You can delete what has been imported or bring in new from Excel overwriting what came in with the package. It is not until you apply the data that it is in the actual working tables.
    Cynthia Priebe
  • 3.  RE: RapidStart Export Packages
    Posted Feb 19, 2020 06:55 AM
    This is true.
    I recommend adding a filter to each table with transactional tables to that you don't bring any data. This will speed up the processing of the import.
    Please excuse the brevity of the response and any mistakes.  Thanks.
  • 4.  RE: RapidStart Export Packages
    Posted Feb 19, 2020 07:56 AM
    Thank you for the suggestions. I will be trying this later today.
    Rachel Boston
    Farmers Pride Inc
    Fredericksburg PA
  • 5.  RE: RapidStart Export Packages
    Posted Feb 19, 2020 08:02 AM
    One other suggestion. As you find holes in your templates, and, if you are like me, you will, make sure to update the Master Company. Then use it to update the other companies and any new companies you create.
  • 6.  RE: RapidStart Export Packages
    Posted Feb 19, 2020 08:07 AM
    Thanks Ron, I will definitely be doing that.
    Rachel Boston
    Farmers Pride Inc
    Fredericksburg PA
