PO Approval Workflow
  • 1.  PO Approval Workflow
    Posted Nov 20, 2019 06:35 PM
    Hi There
    I am working on the Workflow for Purchase Order
    When testing I realized that email notification works well when the PO is
    1. Sent for approval
    2. Rejected
    3. Cancel
    4. Deferred for approval
    But there is no notification sent when the PO is approved
    I am suspecting it maybe on the C/AL side
    Can anyone help
    Yusuf Newland
    MGAC
    Washintgon DC
  • 2.  RE: PO Approval Workflow
    Posted Nov 21, 2019 09:11 AM
    What version of NAV/BC?  I can confirm that for NAV2013R2, there is no email notification for the approval.  You have to watch for the status change of the order,
    NAVUG/D365BC-User Group Focus
    May 18-19, 2019
    Denver, Colorado
  • 3.  RE: PO Approval Workflow
    Posted Nov 22, 2019 09:05 AM
    We use @Juan Crispin's solution. It works great. Check it out here: https://www.navug.com/communities/community-home/digestviewer/viewthread?GroupId=49&MID=10611&CommunityKey=95503735-5a0b-4af1-8326-9bd7bb3b4d3d&tab=digestviewer
    Kaukauna WI
  • 4.  RE: PO Approval Workflow
    Posted Nov 22, 2019 09:31 AM
    Hi Greg
    Thanks a lot for the reply
    I will try and get my license to a developer
    It definitely what i suspected
    Appreciate your assistance
    Have a good weekend
    Yusuf Newland
    MGAC
    Washintgon DC
  • 5.  RE: PO Approval Workflow
    Posted Nov 25, 2019 11:03 AM
    The way I did this with my organization (NAV2017) is:
    • Open the PO workflow
    • Locate the 1st "An approval request is approved." event, which is the final approval step
    • Edit the corresponding Response
    • Add a new line and select, "Create a notification for %1"
    • Once you have added that, highlight/select it and on the bottom of the Response, select the Recipient User ID - this is the user you want to notifiy
      • Repeat if you have multiple notifications.
    This is doable with your standard license and no C/AL modifcations.
    Anthony Rowan
    Ancillare
    Horsham PA
  • 6.  RE: PO Approval Workflow
    Posted Nov 26, 2019 07:19 AM
    Thanks Tony
    Your approach works perfect!!
    Thanks so much
    Yusuf
    Yusuf Newland
    MGAC
    Washintgon DC
  • 7.  RE: PO Approval Workflow
    Posted Nov 26, 2019 09:38 AM
    Good point Anthony. If you always want the final email to go to a specific user, then no customization should be needed.
    The customized workflow solution allows the system to determine who originally requested the approval (requestor), and when the approval occurs, the requestor then receives the notification.  One additional note, is that the customized solution relies 100% on events that Microsoft built into the Workflow system to allow for us to extend it in ways like this. However, it does require a development license.
    Kaukauna WI
  • 8.  RE: PO Approval Workflow
    Posted Nov 27, 2019 07:52 AM
    i am hoping this would work with any workflow, such as journal entry or cheque batch?
    thanks
    cheryl
    Cheryl Pflug
    Financial Officer
    Federation of Students
    Waterloo ON
  • 9.  RE: PO Approval Workflow
    Posted Nov 27, 2019 09:27 AM
    It should, the steps I posted is standard in NAV (2017).
    Anthony Rowan
    Ancillare
    Horsham PA
