Web Client - Change header height
  • 1.  Web Client - Change header height
    Posted 23 days ago
    Hi All
    Anyone know if there's an equivalent to "Change Header Height" for col headers in Web client?
  • 2.  RE: Web Client - Change header height
    Posted 22 days ago
    There is not. Control for position and sizing went away when they introduced the Role Tailored Client with NAV 2009. This isn't just a web client problem.
    However, you do have control over the length of the Captions you use for fields, so some caption abbreviation can usually fix the issue.
    Instead of "Last-Known General Ledger Entry Number", use a caption of "Last-Known GLE No.". Yes, this is a poor example, but hopefully I am making my point :)
    Kyle Hardin
    Business Central Developer
    Atlanta GA
  • 3.  RE: Web Client - Change header height
    Posted 22 days ago
    Figured it out. There is no setting: the header height changes dynamically as you make columns narrower
