NAV Job Queues
  • 1.  NAV Job Queues
    Posted Dec 09, 2019 10:16 AM
    If you have a job set to run every 60 minutes, but occasionally it takes longer than 60 minutes, will it start another copy of the task or wait until the current task is done?
    Joel Baines, PMP, MCP
    Manager - IT
    Oakville ON
  • 2.  RE: NAV Job Queues
    Posted Dec 09, 2019 01:59 PM
    It should run on a continuous loop then.  The Job Queues run based on Earliest Start Time.  When the job finishes executing, it evaluates if the Earliest Start time is current or in the past and will start again.
    Chris Farmer
    IT Project Manager
    TMG Gases
    Bryan TX
  • 3.  RE: NAV Job Queues
    Posted Dec 09, 2019 02:19 PM
    That was what I was hoping.    Continuous loop good.    Running the same job concurrently not so much.
    I was pretty sure of that, but wanted to fact check myself.
    Thanks.
    Navision and EDI Business Analyst
    Oakville ON
  • 4.  RE: NAV Job Queues
    Posted Dec 10, 2019 10:09 AM
    As Chris stated on this one, it the earliest start time is evaluated after the job is complete.  If you schedule 60 mins on the hour, after a while you'll notice the next start time is not on the hour anymore.  I usually have the job stop at a certain time and have it start up again on the hour.  This ensure's it's pretty close to every hour on the hour.
    Jimmy Yu
    Enterprise Architect
    Step Energy Services Inc
    AB
