Replenishment Section functionality
  • 1.  Replenishment Section functionality
    Posted Feb 27, 2019 06:32 PM
    Just recently, ​I have discovered the flushing and scrap % drop down data entry boxes in the Replenishment field are no longer viewable to me when registering an item (or for any existing item card).  These are also no longer selectable when viewing the customize or select column options.  The boxes are simply no longer available to me in the system.  I have checked my user profile and my settings and have the exact same Profile as other users who can still see the complete Replenishment section in the item card.  I am uncertain if there is any function that I may have mistakenly selected that would create this situation. Is there a specific permission such as "Add Item" that is required?  I have the "modify items" permission already.  Has anyone else experienced an issue like this?
    Kirk
    Kirk Simmons
    Goodwill Southeast Georgia
    Savannah GA
  • 2.  RE: Replenishment Section functionality
    Posted Feb 28, 2019 08:12 AM
    What version of NAV are you using? Is this on the Item Card? If it is one of the more recent version, you may need to look at your Application Area setup. You could need to be assigned to the #Manufacturing area. That's the closest thing NAV has to field level security, and if you can't even see it as a field to add in the same place your colleagues can, then it is probably the answer.​
    Matt Traxinger
    San Antonio TX
  • 3.  RE: Replenishment Section functionality
    Posted Feb 28, 2019 11:08 AM
    We are using NAV 2018 Ver 11.0.20783.0.
    Kirk Simmons
    Savannah GA
