Base Qty to Handle Must be Equal to 0
  • 1.  Base Qty to Handle Must be Equal to 0
    Posted Dec 03, 2019 02:58 PM
    Dynamics NAV 2016 user
    When receiving a purchase or transfer order I often receive the error message "Base Qty to Handle Must be Equal to 0".
    I am able to reduce the qty to receive and receive in portions of the shipped inventory before receiving this error.  I have reviewed the reservation entries and other documents and have found that this inventory is not being requested anywhere else in the system.  I have also identified that this is not an issue of what I call a "split line" (where the remaining quantity is split between two entries).
    Why would this exist?
    All insight is greatly appreciated.
    Michelle Cahall
    TGS Global
    Denver CO
    Attachment(s)
    pptx
    Base Qty 0.pptx   13.35MB 1 version
  • 2.  RE: Base Qty to Handle Must be Equal to 0
    Posted Dec 03, 2019 04:19 PM
    Hey Michelle,
    This one can be tricky.  Lets start here - Does the quantity to receive match the quantity to handle on the item tracking lines?
    Nirav Shah
    Solution Architect
    To-Increase
  • 3.  RE: Base Qty to Handle Must be Equal to 0
    Posted Dec 03, 2019 05:31 PM
    It does, however, I am not able to receive the full quantity.
    I am not sure if this is related, but some of these transfer and purchase orders also have an error message in the POS Inventory Updates page stating the following:
    There is no Reservation Entry within the filter.
    That being said, I'm unsure how that would relate being that the full quantity is requested and shipped.
    Michelle Cahall
    TGS Global
    Denver CO
  • 4.  RE: Base Qty to Handle Must be Equal to 0
    Posted Dec 03, 2019 10:14 PM
    What results do you get when you remove the filters, can you find the item/lot no. in the reservation entry table?
    Also check the Order Tracking Policy on the item card - what is that set to.  The setting there can also cause issues in the reservation entry table.
    Nirav Shah
    Solution Architect
    To-Increase
  • 5.  RE: Base Qty to Handle Must be Equal to 0
    Posted Feb 26, 2020 12:18 PM
    I'm using 2016 version.  Can you tell me where I might locate the reservation entry table?
    Michelle Cahall
    TGS Global
    Denver CO
  • 6.  RE: Base Qty to Handle Must be Equal to 0
    Posted Dec 06, 2019 02:40 PM
    Are you using stockkeeping units?
    Xan
    Katy TX
  • 7.  RE: Base Qty to Handle Must be Equal to 0
    Posted Feb 26, 2020 12:15 PM
    I have found that I can receive most quantity and remove the base quantity error.  Once the base qty error is gone I receive a lot information error. "Lot Number is Required for Item"... however, the full quantity has been shipped, but cannot be received.  The full quantity shipped is a single line of data; the quantity is not split across multiple entries.
    Michelle Cahall
    TGS Global
    Denver CO
