"Joins" in Object Designer
  • 1.  "Joins" in Object Designer
    Posted 18 days ago
    Edited by Mark Anderson 18 days ago
    Hi All
    I need to add two related tables to a sales invoice lines
    In SQL the join is as follows and returns the correct result
    SELECT
    FROM
    [dbo].[test$Sales Invoice Header] [ih]
    LEFT JOIN [dbo].[test$Sales Invoice Line] [il] ON [il].[Document No_] = [ih].[No_]
    LEFT JOIN [dbo].[test$Item] [i] ON [il].[No_] = [i].[No_]
    In Object designer, Sales Invoice Line is indentation level 1
    I made item indentation level 2 and my DataIteLink is No = No
    As soon as I do this, my data set contains 2 records for each item
    Anyone any ideas what I'm doing wrong?
    I arbitrarily selected keys for DataItemTableView's for these two new data items so that I didn't get fasttabs in the request dialog
  • 2.  RE: "Joins" in Object Designer
    Posted 8 days ago
    I am assuming You are looking at the dataset in a report?
    If You have a screen-dump of the layout, my guess is that you have fields for the 'Sales Invoice Line'. They will come out before the Item element. To avoind that You need to place all of those fields on the Item level.
    What version are You on? You may be able to use a query instead?
    Henrik Helgesen
    California Cryobank, LLC
    Los Angeles CA
  • 3.  RE: "Joins" in Object Designer
    Posted 8 days ago
    Thanks for reply Henrik.
    We're on 13 on prem. from what I understand you're saying the item and table need to be same indentation level? This is equivalent to left join right? I thought indenting one level was equivalent to a join? Any idea how same level and level + 1 indentation would relate in SQL terms?
    Still very new to Nav, so not sure how I'd hook a report to a query
    Would really like to do as a proper AL extension in near future. Dabbled in AL a bit and understand basics of table relations and made a custom qeury and report there. Still not enough experience of entire AL SDLC to move that way yet (even though I know I'm building technical dbt right now :-))
    Thanks Again
