Requisition Worksheet Lead Time Column
  • 1.  Requisition Worksheet Lead Time Column
    Posted Jan 16, 2020 01:19 AM
    We are working with the requisition worksheet in NAV 2016. There is a column for Lead Time. Our worksheet records are showing a lead time value of 1D. We do not have any lead time values specified in the corresponding fields on the item card or SKU records. Where would these lead times be coming from on the req. worksheet?
    Neil Cates
    Beckwith & Kuffel
  • 2.  RE: Requisition Worksheet Lead Time Column
    Posted Jan 16, 2020 08:14 AM
    The default value for a blank date formula field is 1D.  Same thing holds true for Safety Lead Time, which is why Production Orders finish a day before they are to be shipped.
    Best Regards
  • 3.  RE: Requisition Worksheet Lead Time Column
    Posted Jan 16, 2020 05:44 PM
    Thanks for the reply. Let me make sure that I understand - and ask a follow up. If there is nothing specified, anywhere, in terms of planning for lead time - the default value that we would expect to see on these planning worksheets will be 1D...?
    If we want to change the lead time - is there anyplace to set that for a group of items - or is it item-by-item or sku-by-sku record?
    Neil Cates
    Beckwith & Kuffel
  • 4.  RE: Requisition Worksheet Lead Time Column
    Posted Jan 17, 2020 03:40 AM
    If you are using SKU's you have to do the setup per SKU record.
    If not, you have to do the setup in the Item Table.
    We have added an extra customized table, where we do this setup per vendor/supplier.
    If we create an Item this value will be taken over as default.
    Indivual exceptions per Item we can change manually in the SKU, or do an import for instance with Rapid Start.
    Annette van der Muur
    Application Manager
    Hal Leonard Corporation
  • 5.  RE: Requisition Worksheet Lead Time Column
    Posted Jan 17, 2020 10:04 AM
    In the "Manufacturing Setup" you can establish a global Safety Lead Time.  In the "Inventory Setup" you can establish a global Inbound and Outbound Warehousing Times.  On the "Location Cards" you can establish the location specific Inbound/Outbound Warehousing Time.  Lastly, on each Item Card/SKU Card you can establish Item specific Safety Lead Times.
    For purchase product, you can establish Vendor specific Lead Times in the Item Vendor Catalog table, which is accessible from the Item Card.
    When using Locations it is advisable to use SKUs, and to maintain the information on the SKU records.
    Hope this helps!
  • 6.  RE: Requisition Worksheet Lead Time Column
    Posted Jan 17, 2020 10:12 AM
    We needed to use an extra table, as the leadtime per Location per Supplier can  be different.
    Application Manager
  • 7.  RE: Requisition Worksheet Lead Time Column
    Posted Jan 17, 2020 02:46 PM
    Thanks to everyone for the replies. A lot of good information here.
    Neil Cates
    Beckwith & Kuffel
