Lanham EDI and eShip Posted Package Record Question (Lot/Exp Date)
  • 1.  Lanham EDI and eShip Posted Package Record Question (Lot/Exp Date)
    Posted Jan 31, 2020 03:03 PM
    Does anyone know how the lot number and expiration date get populated in the (Posted) Package Records?
    NAVUG/D365BC-User Group Focus
    May 18-19, 2019
    Denver, Colorado
  • 2.  RE: Lanham EDI and eShip Posted Package Record Question (Lot/Exp Date)
    Posted Feb 03, 2020 07:18 AM
    Good Morning Lewis,
    You need to setup an E-Ship Tracking Code and assign those to the respective items. That will allow you to assign Lot / Exp to Packages automatically.
    Dale Raffauf
    In-Sys Solutions
    Libertyville, IL
    847-996-0400
    draffauf@in-sys.com
  • 3.  RE: Lanham EDI and eShip Posted Package Record Question (Lot/Exp Date)
    Posted Feb 03, 2020 09:21 AM
    I agree with Dale, You need to setup the E-Ship Tracking Code on all Items that require this info.
    It is not automatic, The shippers need to input the LOT and/or EXP Date before closing the package, the E-Ship Tracking Code makes it required so they cannot close the order without this info.
    We automate it by creating a Bar Code on our packages in the format of ITEMNumber;LOTNumber
    When they scan this bar code it automatically inputs the Lot Number on the package.
    We do not have them enter the EXP Date.
    For Customers that require EXP Dates on the EDI Documents we had a Custom EDI Out created that pulls the EXP Date from the Lot Information Card based on the Lot Number that was packed in the box.
    Justin Falconer
    Tender Corporation
    Littleton NH
  • 4.  RE: Lanham EDI and eShip Posted Package Record Question (Lot/Exp Date)
    Posted Feb 03, 2020 05:30 PM
    I see that it is not automatically updated.  That is too bad since the information is on the registered pick.
    So where do you go to update the packages?
    May 18-19, 2019
    Denver, Colorado
  • 5.  RE: Lanham EDI and eShip Posted Package Record Question (Lot/Exp Date)
    Posted Feb 03, 2020 06:52 PM
    What happens if they pick multiple Lots for one shipment, Eship has no way to know what LOT is in What Package and is the reason it does not auto populate.
    You add the Lots by using the command  //SASL (Scan All Serial and Lot) or //SMSL (Scan Missing Serial and Lot)
    Justin Falconer
    Tender Corporation
    Littleton NH
  • 6.  RE: Lanham EDI and eShip Posted Package Record Question (Lot/Exp Date)
    Posted Feb 04, 2020 09:21 AM
    Justin, thanks for the reply.  I understand what you are saying...we tend not to think that way because we have one item to a package.  The //SMSL command worked, but this is not really a very good solution.  We can have hundreds of packages on an order and we create our packages and labels before we go out an pick an order.  We build the pallet as we pick, so it is too late to create and apply labels after picking.  So, I guess we're going in the right direction with a modification we have planned where we will scan the bin, scan the item/lot bar code, and scan the UCC label to populate the package records as we pick.
    May 18-19, 2019
    Denver, Colorado
