RapidStrart Customers
  • 1.  RapidStrart Customers
    Posted 11 days ago
    Hi All
    Created a rapid start package for customers and another for contacts
    When I imported customers and went to the customer list, the name/address, etc were empty.
    I them imported the same data as contacts of type company and it populated the names and addresses
    However when try to  update a customer record in rapidstart I get this:
    "Contact CT00141 XXXX is not related to customer C00141 XXXX" on "Primary contactNo"
    When I look in Contact Bus Relations, I see the record
     CT00141 /  CUST  / 1 /  C00141
    Any idea what could cause this?
    Thnaks
  • 2.  RE: RapidStrart Customers
    Posted 10 days ago
    Edited by Nirav Shah 10 days ago
    Mark,
    I cannot troubleshoot your specific error without seeing your import files and how your customer records are stored.  But below is the steps I generally follow and you can compare to your process in importing customers/contacts:
    1. Import customers
    2. Ensure the business relations table is empty
    3. Ensure contacts table is empty
    4. Export the empty "contacts" table into excel
    5. Run "Create Contacts from Customer" function to get the initial customer company contact records created.
    6. In my contacts export excel file (step 2), fill in your "person" contact details and ensure the correct "Company Contact No." is populated to each person contact.
    7. Check contacts table for successful import.
    Hope this helps!
    Nirav Shah
    Solution Architect
    To-Increase
  • 3.  RE: RapidStrart Customers
    Posted 9 days ago
    Thanks Nirav
    Importing customers and then running the report worked. Found out before I read this :-)
    Thanks for taking time to respond
    Best
    mark
  • 4.  RE: RapidStrart Customers
    Posted 10 days ago
    If you are sure the data is correct for the customer in all fields. I will say uncheck the validation on all of them. Then import the customers only.
    If they come inside correctly. Then import the contacts and Contact Business Relation again together.
    Choice 2: In the Rapid package, export 1 good customer to Excel. This way the format is given, then format the data into the Excel layout they provided and import it.
    Good luck.
    Geovanny Fuentes
    San Diego CA
  • 5.  RE: RapidStrart Customers
    Posted 9 days ago
    Thanks Geovanny
    Tried all of that. Created customer and contact from scratch, formatted my Excel exactly same. Didn't work
    Result was frustratingly simple:
    Import customers
    Run report "Create Contacts from customers"
    8 hours of my life I'm not getting back :-)
    Hopefully someone else will benefit from this nugget later :-)
  • 6.  RE: RapidStrart Customers
    Posted 9 days ago
    Simply put, this error happens when you enter a value into the "Primary Contact Code" on the Customer Card that is for a contact that is not related to this specific customer.  So you need to check the Customer rapid start package and see why you are setting the "Primary Contact Code" with a Contact that is related to another customer.
    Also I strongly agree with Nirav that you should run "Create Contacts from Customer" to create all of the company contacts.
    Curious to see how far these and other suggestions on this thread have gotten you.
