Hi All
I'm writing automated tests for one of our extensions (BC2020 wave 1) and I need to confirm that the validation message is correct as part of the test.
Let's take a simple (made up) case
Record.Field1 cannot be more than 2x it's current value.
The extension would have an Subscription to the OnAfterValidateEvent and raise an error such as this:
Error(StrSubstNo(QtyTooHighMsg, Format(MaxQty)));
In the UI, I get the red X, and when I hover over it I see a message that is something like this "The number entered is too high. The max value is 20"
So My test would create a record with value 10 and then do record.Validate(Field1, 25). My asserterror catches the error and the test continues,.but I want an assertion that the validation message did, in fact say "The number entered is too high. The max value is 20"
I don't see any kind of HandlerFunction Attribute that I can use to test this. Did I miss something?
If not, is there another way?
Finally is here a way in the test to "click" revert?
