Print Ledger View
  • 1.  Print Ledger View
    Posted 16 days ago
    We recently upgraded from NAV2009 RTC to D365BC and noticed that the print (or export to excel report) capability at the ledger screen view is no longer available.  Is there any way to get this print functionality back?
    To provide a bit of context, when we create a payment journal our process is to print (or export it to excel report) and send to Exec team for payment approval prior to printing and posting checks.  This no longer appears to be an option.  We also used the ledger print function for quick ad-hoc review of different ledger analyses.
    I'm aware that the new workflow approval function could alleviate the payment journal approval issue, but we're not quite ready to dig that deep or train our Exec team on the workflow approval process.
    Any thoughts would be much appreciated.
    Nate
    Nathan Romney
    CFO
    Martori Farms
    Scottsdale AZ
  • 2.  RE: Print Ledger View
    Posted 16 days ago
    From the Payment Journal menu, go to Page, then Edit in Excel.
    To Excel
    You must have the Excel Addin installed and be logged in to get the data into the workbook that opens.
    Excel from payment journal
    Cynthia Priebe MCP, DCP
    Join us at User Group Focus in Houston, March 13-14, 2019.
    Woo-hoo! There is a track for Business Analysts this year.
    Join me and my co-panelists and presenters at the following sessions:
    BAN75 - Ask the Analysts
    CFO90 - Ack! My A/P Person Just Left, What Do I Do Now?
    Not for you, check out the other great content at https://www.ugfocus.com/focus/locations/houston/houston2
  • 3.  RE: Print Ledger View
    Posted 16 days ago
    Thanks Cynthia.  We tried the Edit in Excel method, but it doesn't seem to provide the key field needed to approve payments, Payment Due Date.  Any way to pull in the Payment Due Date?
    Nathan Romney
    CFO
    Martori Farms
    Scottsdale AZ
  • 4.  RE: Print Ledger View
    Posted 15 days ago
    ​Have you played at all with the Design mode in the Excel Add-In? This functionality is nearly identical to personalizing your screen so will have an additional list of fields you can add to the document. Once you add and remove fields you will want to refresh the data which will pull the details for your additional field.
    You can also use this mode to adjust filters and even add excel functions directly in your data tables. The tool is definitely a work in process but has pretty good functionality for adjusting after you get the base details (you can even add more sheets for other data points).
    I have seen the old Export to Excel show up on some pages recently so I think they are working on getting that functionality back embedded into the interface but it isn't there yet.
    Let me know if you need any more details on the design mode!
    Spencer Coulter
    Manager, Business Applications
    RSM US LLP
    E: Spencer.Coulter@rsmus.com
  • 5.  RE: Print Ledger View
    Posted 16 days ago
    Nathan,
    So the real issue is not that you can't export to Excel, it is that what is exported is missing the Applies-to Doc Due Date column, correct?
    If yes, I would submit this to Microsoft. This was probably an oversight.
    Maybe temporarily you can use the Cash Requirements by Due Date (printed with detail) for what you are trying to accomplish. This report can be printed or sent to Excel.
  • 6.  RE: Print Ledger View
    Posted 15 days ago
    Hi Nathan,
    Based on your specific scenario, I would suggest using the Vendor Prepayment Journal, located under Actions --> Posting in the Payment Journal.  That report provides the details of the loaded payment journal that can then be sent to the team for review/approval prior to printing the checks.
    Lisa Doran
    Onalaska IN
  • 7.  RE: Print Ledger View
    Posted 15 days ago
    @Lisa Doran great suggestion! ​
