Kit/ Kitting/ Assembly Picking from Sales Order
  • 1.  Kit/ Kitting/ Assembly Picking from Sales Order
    Posted Apr 06, 2021 12:08 PM
    Hi everyone,
    Does anyone know if there is a way to create a sales order for a kit and have the components print out on a picking sheet to be later processed through pack line scanning. I am attempting to roll this into our regular shipping process as a pick and pack situation. We are using Business Central 14.20.
    Thank you for your help,
    Schrell
    Schrell Tipton
    Manufacturing Manager
    Ellsworth Corporation
    Germantown WI
  • 2.  RE: Kit/ Kitting/ Assembly Picking from Sales Order
    Posted Apr 06, 2021 04:43 PM
    Schrell,
    Base Business Central, for Assembly BOM, when you create the Sales Order you enter a single Sales Line for that Item. If I printed a picking instructions only the Kit Item would appear. Now, I can Explode the Assembly BOM on the Sales Lines and then the Assembly Components will appear on the Pick Instructions, but the Assembly Item No. will not. If you want to have the Sales Order show the Assembly Item and have the Assembly BOM explode only on the Pick Instructions, then you could work with your Partner to accomplish this.
    Hope this helps.
  • 3.  RE: Kit/ Kitting/ Assembly Picking from Sales Order
    Posted May 06, 2021 12:32 PM
    Thank you Steve. I will contact my NAV/ BC partner.
    Schrell Tipton
    Germantown WI
  • 4.  RE: Kit/ Kitting/ Assembly Picking from Sales Order
    Posted Apr 07, 2021 08:38 AM
    Do you have bins enabled?  Are the items setup as assemble to order?
    If you do on the location you will need to set the to-assembly  and from-assembly bins.
    Then on the assembly setup turn on the Create Movements Automatically.
    When the pick is created it will create for the assembly components and not for the finished item.
    Kevin
    Kevin Fons
    Bozeman MT
  • 5.  RE: Kit/ Kitting/ Assembly Picking from Sales Order
    Posted May 06, 2021 12:33 PM
    Thank you Kevin. I will do some testing with the Assembly function.
    Schrell Tipton
    Germantown WI
