You can also set this discount on the Customer Disc. Group or Campaign. Yes, but it should be in advance.
Bear in mind the basic behavior of NAV. When a Sales or Purchase line is modified, NAV will validate the entire line. If there are no special arrangements with the customer/vendor and the item, NAV will revert back and remove any discounts. You will need to reach out to your developer to bypass that behavior to satisfy your needs.
Good Luck!
Alfredo Zelaya
Sr. Systems Analyst
Megadyne Americas LLC
Fairfield NJ
Sent: Dec 30, 2019 07:48 AM
Subject: Maintaining a Line item Discount with change in Qty.
Thanks for reply Alfredo
I believe your solution requires setting a line item discount for the customer in advance doesn't it?
We need to be able to enter ad-hoc discounts (at sales reps discretion) and not have them get wiped out if the qty changes later
We also need to be able to apply the same discount to every line on 40-50 line orders (we can;t use invoice discounts)
Sent: Dec 27, 2019 09:23 AM
Jason
Attached is a quick and dirty instruction sheet on adding a line discount to an item/customer combination. There are many combinations this can be done, this is just one.
Replicate it and fool around a bit.
Good Luck
Alfredo Zelaya
Sr. Systems Analyst
Fairfield NJ
Sent: Dec 26, 2019 01:11 PM
Is there a way to maintain a line item discount % when you change the order quanity on the line item?
Jason Natanson
Evanston IL
