Correspondence Type on Contact Card
  • 1.  Correspondence Type on Contact Card
    Posted 20 days ago
    When setting up the correspondence field with in Nav. How would you determine which of the three option available (hard copy, email, fax)is to be set against that contact?
    Jason A. Natanson
    Jason Natanson
    Evanston IL
  • 2.  RE: Correspondence Type on Contact Card
    Posted 19 days ago
    Hi:
    This field is used to determine what communication method should be used.  I've used it primarily in campaigns and segments when you're sending mail blasts to contacts.
    Good luck!
    Murphy McConnell
    Stoneridge Software
    Murphy McConnell
    Stoneridge Software
    Fargo ND
  • 3.  RE: Correspondence Type on Contact Card
    Posted 19 days ago
    Jason,
    This is a default setting for the Contact.  It can be changed when you are creating a new interaction.  If you are just starting to use the Relationship Management functionality in Business Central, I would recommend using the method you most commonly use to interact with your contacts now.  Have the Users update the type of communication, when they use another method for their interactions.  After a month or two, you can review the logged interactions and update this field on the contacts where necessary.
    Robb Delprado
    Senior Trainer and Consultant
    robb@newviewstrategies.com
    860.558.8032
    Houston, TX
