Address Validation at Order Entry
  • 1.  Address Validation at Order Entry
    Posted 12 days ago
    Wondering if there is an Add-on available for NAV18 for Address Validation (with USPS) that would occur at point of Order Entry?  Ideally with a call to action button that could be activated when desired?  Sana Web integration a plus!
    Thanks for any leads,
    April Humphrey
    VP/Controller
    West Music
    Coralville IA
  • 2.  RE: Address Validation at Order Entry
    Posted 11 days ago
    If you use Avalara you can do this with Avatax. You can set up the release function to also do address validation. I know we use this not only for B2B, our varying websites (Woo and Magento backed) and our SalesForce B2B portal. If you use Avatax with Sana should be able to use it there as well.
    Andrea Riviezzo
    IT Manager - NAV
    Charlotte's Web, Inc.
    Louisville CO
  • 3.  RE: Address Validation at Order Entry
    Posted 11 days ago
    I like Andrea's idea of utilizing a solution you might already have. If you don't have AvaTax, I believe SureTax and Lanham both have Address Validation add-ons.
    If none of that works for you, then I would probably try a simple, integration with something like this: https://smartystreets.com/products/apis/us-street-api
    Appleton WI
