Show "Notes" factbox from related record
  • 1.  Show "Notes" factbox from related record
    Posted 23 days ago
    I had a request today to do show the notes factbox from record A--on a page that is for record B. Example: When viewing the sales order you could also see a "Notes" factbox that are notes for the Sell-To Customer record.
    We've done this before using Kine's solution from back in 2009 detailed here . Basically you put the System "Notes" factbox inside an otherwise blank factbox that has Customer as it's source table and uses SubPageLink to get the proper customer record. I know this used to work in 2009 R2. But I can't get it to work in 2016.
    Anybody have any luck making this work in any of the newer versions?
    Kaukauna WI
  • 2.  RE: Show "Notes" factbox from related record
    Posted 22 days ago
    Edited by Geovanny Fuentes 22 days ago
    In this post he discusses how to read the notes and how to create the notes pro-grammatically. When you create a note where the data is saved in the Navision ? I have seen this question being asked several times in the community forum. The answer is the notes are saved in binary format in a blob field (Note) in the Record Link table (2000000068) and the way it maps to the record is using Record ID.
    http://www.navisionworld.com/2015/11/how-to-readwrite-notes-in-navision.html
    Good luck.
    Geovanny Fuentes
    San Diego CA
  • 3.  RE: Show "Notes" factbox from related record
    Posted 21 days ago
    Unfortunately that is not quite what I'm trying to do Geovanny. ​I am attempting to show the notes using the system factbox. But I wish to have the factbox show the notes from a different table than the current page's source table. Has anyone found a way to do this in the more recent versions?
    As a sidenote, if you're wanting to know how to handle record link notes with code, I'd also suggest this post from @Tom Hunt at ArcherPoint: https://www.archerpoint.com/blog/Posts/how-show-notes-related-table
    Kaukauna WI
  • 4.  RE: Show "Notes" factbox from related record
    Posted 22 days ago
    @Greg Enns, we you get this to work, will you share your steps?​
