can't get sessions to work
  • 1.  can't get sessions to work
    Posted Nov 30, 2018 10:10 AM
    I have access to sessions, but get the error that I have no internet browser installed when I try to open it.  Any ideas, I definitely have an internet browser on my PC.  We are using NAV 2016.
    Chastity Branham
    Georg Utz, Inc
    Edinburgh IN
  • 2.  RE: can't get sessions to work
    Posted Dec 03, 2018 07:28 AM
    Sounds weird.  Can you post a picture of the error?  Do you use the web client?
  • 3.  RE: can't get sessions to work
    Posted Dec 04, 2018 11:19 AM
    If you can't still access it, here is a SQL script you can use for now under SQL Studio Mgt Studio.
    Just change the [YourDatabaseName] to your actual database name.
    You can copy/paste the 3 separate ones and run them as once if needed.
    Good luck
    SELECT *
      FROM [YourDatabaseName].[dbo].[Active Session] a
      inner join [YourDatabaseName].[dbo].[User] as b
      ON a.[User SID] = b.[User Security ID]
      where b.[License Type] = 0 and a.[Client Type]=0
    exec sp_who2
    SELECT *
    FROM sys.dm_exec_sessions
    WHERE program_name LIKE  '%Microsoft Dynamics NAV Service%'
    SELECT
        SPID                = er.session_id
        ,STATUS             = ses.STATUS
        ,[Login]            = ses.login_name
        ,Host               = ses.host_name
        ,BlkBy              = er.blocking_session_id
        ,DBName             = DB_Name(er.database_id)
        ,CommandType        = er.command
        ,SQLStatement       = st.text
        ,ObjectName         = OBJECT_NAME(st.objectid)
        ,ElapsedMS          = er.total_elapsed_time
        ,CPUTime            = er.cpu_time
        ,IOReads            = er.logical_reads + er.reads
        ,IOWrites           = er.writes
        ,LastWaitType       = er.last_wait_type
        ,StartTime          = er.start_time
        ,Protocol           = con.net_transport
        ,ConnectionWrites   = con.num_writes
        ,ConnectionReads    = con.num_reads
        ,ClientAddress      = con.client_net_address
        ,Authentication     = con.auth_scheme
    FROM sys.dm_exec_requests er
    OUTER APPLY sys.dm_exec_sql_text(er.sql_handle) st
    LEFT JOIN sys.dm_exec_sessions ses
    ON ses.session_id = er.session_id
    LEFT JOIN sys.dm_exec_connections con
    ON con.session_id = ses.session_id
    Geovanny Fuentes
    San Diego CA
