BC 14 (On Premise) Object Import Takes A Long Time To Complete
  • 1.  BC 14 (On Premise) Object Import Takes A Long Time To Complete
    Posted May 05, 2021 02:36 PM
    Since a recent upgrade from NAV2013R2 on premise to Business Central 14 on premise, I noticed that when I upload a single fob file into the Development Environment, it takes a long time and appears to build and object search index reviewing every object.  A similar upload used to take just seconds.  Is there a setting somewhere that changes this behavior?
    D365UG-BC/NAVUG All-Star
  • 2.  RE: BC 14 (On Premise) Object Import Takes A Long Time To Complete
    Posted 25 days ago
    Hi Lewis,
    Building Object Search Index is the step which updates the references for the modern client.
    If you are not using the modern client (web client) you can cancel executing of this step.
    Saurav Dhyani
    Upgrade Technical Futurist
    Archerpoint Inc.
    Dehradun, India
    Blog - https://www.sauravdhyani.com/
  • 3.  RE: BC 14 (On Premise) Object Import Takes A Long Time To Complete
    Posted 24 days ago
    Thanks for the response, Saurav.  I hope you are well!
    We are still using the Windows Client.  This process used to take just seconds and now takes several minutes.   Based on your response, I assume this is expected behavior due to the modern client.
  • 4.  RE: BC 14 (On Premise) Object Import Takes A Long Time To Complete
    Posted 22 days ago
    Hi Lewis,
    I am good and hope you are doing well.
    Business Central 13 & 14 have this issue as both these versions have both client available (Modern & Windows).
    To update the Search option for Modern client system tries to Build Object Search References in Version BC13 and BC14 only.
    As you are only using Windows client you can safely cancel this step during object import or object compilation.
    Saurav Dhyani
    Archerpoint Inc.
    Dehradun, India
