Released Production Order, Start Date Issue #NAV 2015 #MANUFACTURING
  • 1.  Released Production Order, Start Date Issue #NAV 2015 #MANUFACTURING
    Posted Feb 07, 2020 12:00 PM
    We are running NAV 2015
    We are encountering an issue with our start dates on Released Production Orders jumping to 12/31/2019 every time a quantity is changed and the RPO is refreshed.
    I have checked User posting dates. I have updated the Work Center Calendars.
    I know I should have encountered this before, but I'm stumped.
    Please help!
    [Paul] [Cochrane]
    [IT Program Manager]
    [Columbus Vegetable Oils]
    [DesPlaines] [IL]
    Check out the Chicago UG LinkedIn Page https://www.linkedin.com/groups/8868597/
  • 2.  RE: Released Production Order, Start Date Issue #NAV 2015 #MANUFACTURING
    Posted Feb 10, 2020 10:19 AM
    Paul - usually when the dates are suspect in Production scheduling it does have to do with Work Center/Machine calendars. In your note the Work Center Calendars were checked - one question are you using machines? If so, do any of the Work Centers have Consolidated Calendars marked which simply means the load is coming from the associated machine centers. The sequence of building capacity on Work Centers would then mean you run calendars on machines first then Work Centers.
    Just listing some basic calendar setup items to cross off as the issue.
    Best Regards
    John Grant
    John Grant
  • 3.  RE: Released Production Order, Start Date Issue #NAV 2015 #MANUFACTURING
    Posted Feb 12, 2020 10:44 AM
    I forgot to update the Machine Center calendar. Thanks!
    [Paul] [Cochrane]
    [DesPlaines] [IL]
