Bin Column for Item Ledger - Phys Inventory Journal Format
  • 1.  Bin Column for Item Ledger - Phys Inventory Journal Format
    Posted Dec 03, 2019 02:54 PM
    I am using Dynamics NAV 2016.  We use lot tracking for our products and have many bins per location.  I only know to use the physical inventory journal to review bin contents on a mass level, but I dislike the format of the journal (it's not easily manipulated in Excel for what I'm trying to achieve).
    Is there an easy way to adjust the physical inventory journal export to have a more csv type format that can be thrown into pivot tables and compared quickly?
    Am I able to revise the way the item ledger looks to include a column to list bins?  That's currently not an option and I don't have access to speaking with a developer so all insight is greatly appreciated.
    Thank you!
    Michelle Cahall
    TGS Global
    Denver CO
  • 2.  RE: Bin Column for Item Ledger - Phys Inventory Journal Format
    Posted Dec 03, 2019 05:58 PM
    You cannot look at bins in the Item Ledger.  The item ledger does not go to that level.  You can use the Bin Contents lookup to see inventory at the bin level.  If you "Customize" the Bin Contents page, you can add the Lot Numbers by Bin Factbox.
    Bin Contents Factbox
    Bin Contents
    (You can also filter for a lot number)
    NAVUG/D365BC-User Group Focus
    May 18-19, 2019
    Denver, Colorado
  • 3.  RE: Bin Column for Item Ledger - Phys Inventory Journal Format
    Posted Dec 04, 2019 10:35 AM
    There is no ability to develop a code to allow the option to list the bin in the item ledger entries columns?
    Michelle Cahall
    TGS Global
    Denver CO
  • 4.  RE: Bin Column for Item Ledger - Phys Inventory Journal Format
    Posted Dec 04, 2019 11:15 AM
    There is no bin code field in the Item Ledger Entry table.  You would be better off looking at Warehouse Entries to see bin level inventory transactions.
    May 18-19, 2019
    Denver, Colorado
  • 5.  RE: Bin Column for Item Ledger - Phys Inventory Journal Format
    Posted Dec 04, 2019 10:50 AM
    Have you looked into Warehouse Entries?  It tracks every movement of goods in the warehouse at the bin level.
    You should be able to export the full Bin Contents table as well into Excel for easy manipulation.
    Eric Moe
    Global Supply Chain Manager
    Industrial Revolution
    Tukwila WA
